save as earlier labview version?
We have a bunch of LV2010 code that a guy loaded. changed, then saved back using LV2011.  Yes I know we should update to 2011 but management is spooked about updating even though we own both.
What does it take to save the code back as 2010.  No new 2011 features were incorporated, only visual cleanups were performed.
(2,076 Views)
Accepted by topic author t_houston
According to this, you've been programming LabVIEW for a couple of decades so I find it hard to believe you've never looked at the File menu. You can do the Save for Previous from either your top level VI or from your project.
(2,073 Views)
Its called cranial rectumitus.  You get used to doing the same thing over and over and never stop to look around.  I found it shortly after posting this.  Sorry.
(2,067 Views)
