rs-232 to USB converter trouble
Hi, everyone
I have developed an application in labview 6.1 for communicating with an instrument via serial port, using serial compatibility VIs. the software works ok in the development machine which has a rs-232 port, but i can´t make it start in other PCs using USB to RS-232 converters (since they don´t have a serial port, only USB). I simply can´t stablish communications, BUT if I open hyperterminal (just open it, i don´t send any commands or anything else) and then close it again, the application in labview works ok!!! it´s just like hyperterminal "wakes up" my instrument! does anybody has any idea how can hyperterminal do this???
(2,910 Views)
Are you using the Serial port init vi? Is there any error code coming out?
Paolo
Paolo
(2,901 Views)
Yes, i´m using the seral port init.vi; I haven´t checked the error out, since i didn´t have any problems on the develpoment machine, what kind of error could i get?
(2,891 Views)
