rounding off to nearest decimal point
@RavensFan wrote:
One other comment about rounding.  LabVIEW uses banker's rounding which takes any value that is dead on 0.5 and will round it to the nearest even integer.  Generally in school we would have learned that 0.5 would be rounded up.
So nearest even integer may or may not be what you are looking for.
Don't forget to mention that banker's rounding is the industry standard and not just some arbitrary NI decision.  😉
Bill
CLD
(Mid-Level minion.)
Message 11 of 18
(2,967 Views)
Jeff,
what is the X value and what is the d value?
X would be number i want to round off to?
Message 12 of 18
(2,955 Views)
@super_saiyans wrote:
Jeff,
It you read the thread I linked you would see it is a LabVIEW implementation to duplicate the ROUND(X,d) function in Excel
ROUND function
This article describes the formula syntax and usage of the ROUND function in Microsoft Excel.
Description
The ROUND function rounds a number to a specified number of digits. For example, if cell A1 contains 23.7825, and you want to round that value to two decimal places, you can use the following formula:
=ROUND(A1, 2)
The result of this function is 23.78.
Syntax
ROUND(number, num_digits)
The ROUND function syntax has the following arguments:
  • number    Required. The number that you want to round.
  • num_digits    Required. The number of digits to which you want to round the number argument.
"Should be" isn't "Is" -Jay
Message 13 of 18
(2,945 Views)
i am having problem with this rounding off thing because i only want to look at certain points in my array
in this roundoff method..i have to select the whole array?
can you guys look at my code and sugguest a cleaner methold?
Message 14 of 18
(2,944 Views)
X is the number you want to round.
d is the power of 10 you want to round to.  So to round to the nearest 0.1, but in -1.  Round to the nearest 10, but in +1.
Message 15 of 18
(2,941 Views)
nevermind..its my fault
the rounding methods are good!!!!!
Message 16 of 18
(2,923 Views)
I think you still should use Lynn's method that relies on the smallest difference of absolute values.  This way is TOTALLY unambiguous and doesn't rely on someone's "best guess" which is what rounding really is.
Bill
CLD
(Mid-Level minion.)
Message 17 of 18
(2,904 Views)
smart. Thanks
Message 18 of 18
(2,406 Views)
