rotate a ploted 3d graph around an axis
Hi ,
I am trying to make something like a CAM simulator , I started with a fixed object (cylinder) and a cutter (also cylinder) and i am trying to make the cutter to rotate around the axis of the cylinder and tangent to the top surface of the cylinder.
I attached the VI plus a video for what happened with me.
Message 1 of 12
(5,977 Views)
hi hosa200,
you might have missed to attach the vi.
ps: fill the controls with values, make them all default, so ppl trying to help you can play around, without guessing what values should be.
also don't forget to include subvis.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 12
(5,958 Views)
I update everything as you mentioned ,thank you
Message 3 of 12
(5,943 Views)
Your description of the cutter orientation doesn't quite make sense to me.  Is this what you mean?
aputman
Message 4 of 12
(5,929 Views)
The cutter rotation axis is perpendecular on cylinder rotation axis
like this
Message 5 of 12
(5,918 Views)
like this
Ok, that is the way I interpreted your description but it didn't make sense from a machining point of view (coming from a non-machinist).  Smiley Very Happy
Your x values remain the same in the second Matlab script but I think it should be your z values remaining constant.  I can't open your VI to make sure.
aputman
Message 6 of 12
(5,915 Views)
I am using Labview 2016 ,
Message 7 of 12
(5,913 Views)
Right.  And I am using 2012.  I can only see your picture and from there, I can't see which axis is x, y, or z.  Obviously, based on the video, you are changing the wrong values, so I am assuming that X is parallel to the top of the cylinder and should remain constant.
aputman
Message 8 of 12
(5,909 Views)
2012 version
Message 9 of 12
(5,903 Views)
Sorry, I don't have a license of Mathscript to execute.  So assuming that your code for drawing the cylinder around the axis is correct (only the wrong axis was chosen), this is what I had in mind for the second MathScript node:
mXcut2=mXcut*sin((c*pi)/180);
mYcut2=mYcut*cos((c*pi)/180);
mZcut2 = mZcut;
aputman
Message 10 of 12
(5,900 Views)
