ring text working differently in development end vs ex environment?
Hi All,
The ring text somehow is working differently in the development environment vs the exe
environment.  I can't seem to figure out why.
I have attached the vi of the front panel and the block diagram.
Basically, I want to delete the text/number in the ring text after I've used it.
It works in the development environment but not in the exe environment. I've tried
different ways.
This is a subVI so I am only including the subVI.
The second attachment is were I am trying a different way but result is the same...exe doesn't work as in the development environment. The text/number in the ring text isn't deleted in the exe environment.
(2,533 Views)
You need to edit the Strings[] property if you want to remove an item from the list.
GCentral
(2,522 Views)
Yes, I remove the items from the list with successfully in the development environment. However, in the exe environment it doesn't seem to work.
Anyone else?
(2,467 Views)
Accepted by topic author Jose_LabVIEW
Hi All,
I've solved the issue. Somehow it works,  (removing text on the ring text in the exe environment) on 2013 Pro version but not in LV 8.5 Pro Version. I don't know if this is a software bug?
(2,450 Views)
HI Jose,
again: you need to edit the "Strings and Values" array to remove items from the ring!
(2,439 Views)
