reversing set of mathematical equations VI?
Hi All..
I want to perform a mathematical process which has symetric parts. For example, perform  A=i+(i+1), when A=B reverse the calculation..
If you have look attached VI that I m trying to construct  it s easier to understand what i mean.  Is there any easy way to reverse a VI that performs a mathematical calculation?
thanks
(3,604 Views)
Hi looser,
here's my solution 🙂
(3,598 Views)
I can not open it with 7.0 😞
(3,590 Views)
Hi looser,
I already noticed this - please do note your labview version when you upload a vi!
(3,588 Views)
worksss.. multi thanks.. .
it ll take sometime for me to understand to understand this clever vi 🙂
(3,583 Views)
Hi looser,
instead of 'reversing the mathematical function' I just change the increment to positive/negative.
Please keep in mind: NEVER test floating point numbers for equality - use ALWAYS '>=' or '<='! Floating point numbers have only limited precision, so you get rounding errors very fast after repeated adding operations...
(3,578 Views)
thanks for advice
(3,556 Views)
