return Argument to CMD
Yes, this is the only option I can find at now. thank you.
Message 11 of 13
(1,186 Views)
Or named pipes...
That sounds complex, but there are command line commands for them ("\\.\pipe\my_named_pipe"), and with .net it's easy in LabVIEW. It doesn't fit your exact situation, but if you need a continues two way stream between command line and LabVIEW, it works like a charm.
Message 12 of 13
(1,179 Views)
Sam Sharp in an earlier post linked some thread in LAVA forum where the problem has been solved.
I took a look at a couple of them. They use .NET to attach a console to the LabVIEW program process.
Paolo
Message 13 of 13
(1,170 Views)
