06-23-2015 11:58 AM
I have a 9188 compact Daq chassis with a fixed IP address. In MAX, what will restart and reset do to it? Will either wipe out my static IP address, etc.? Thanks.
Solved! Go to Solution.
06-23-2015 12:02 PM
It will reboot the remote system. If the IP is static, the IP will remain. If you have it set to DHCP, then you may get a new IP.
06-23-2015 01:33 PM
Ok. I was expecting "reset" to be just like hitting the little black button on the chassis. -Thx.
