01-05-2010 11:07 PM
Dear friends,
I using microsoft calender in my application through labview.Im using the calender in IPC which is small size...
so im in need of change the size of calender.
Is it possible?
kavitha
01-05-2010 11:12 PM
01-05-2010 11:40 PM
hai kavi ,
i ve seen ur doubt about calender on (6.1.2010). u can resize the container and u can see more month in one window but u can't zoom a single month.
regard
sathish j
maximus_sjc42@yahoo.co.in
01-05-2010 11:45 PM
friends,
Sorry a change in my question iwant to enlarge the calender size
I attached the calender picture i want to enlarge that only.
01-05-2010 11:57 PM
01-06-2010 12:00 AM - edited 01-06-2010 12:01 AM
01-06-2010 12:55 AM
Hi krishna,
I want to enlarge the calender box why because im using it in a touch screen monitor .This calender box is quite small so its
difficult to use .
01-06-2010 02:46 AM
I dont think you can increase the size of that calender box.Just right click on the control and set time to now which will set the time to present time.But you can create your own timestamp control using some other calender which will change during the run time.
Thanks and regards,
srikrishnaNF
01-06-2010 03:03 AM
How to use some other calender with my timestamp?
01-06-2010 04:28 AM
why dont you use an Activex to create the calendar and resize to what ever you want to...See the attached vi
Guru
