03-16-2020 09:00 AM - edited 03-16-2020 09:04 AM
hi
i have found a lot of analogue clock examples but thing that i want is adjustable analouge clock which I can adjust time via needles to set hour , minutes and second in example in the file attached on 00clockmainUI i want to make the clock adjustable via spinning needles by the user.
does any one has a proper example?
thank you
Solved! Go to Solution.
03-16-2020 09:08 AM - edited 03-16-2020 09:09 AM
Hi ehsan,
two notes:
03-16-2020 10:07 AM
your right.I didn't realize that , i'm sorry.
your second statement is correct but now the problem is the maximum scale range for 3 needles is the same whereas i want maximum for second and min become 60 and for the hour become 12.
03-16-2020 10:09 AM
03-16-2020 10:21 AM
i don't understand. how?
i choose properties then scale tab i see only one maximum scale range as the picture attached. how can i make for each needle separated maximum range?
03-16-2020 10:25 AM - edited 03-16-2020 10:25 AM
Hi ehsan,
You can't apply different scales for the different needles, all share one scale range in the gauge control.
But in your code you can apply another scale on the hour needle: it's simple math…
03-16-2020 10:38 AM
alright.
i'll be grateful if you show me an example.
03-16-2020 11:01 AM
03-16-2020 11:38 AM
thanks a lot
