Hi Christine,
Do you have these same problems with the Report Generation examples if the Report Generation Toolkit (RGT) is not installed? Try uninstalling the toolkit, then running the examples in the [LabVIEW]\examples\reports folder and see if they work. If they do, then it does sound like an issue with RGT 1.1.1, although I've never seen this issue before. So if the VIs are only broken when RGT is installed, you may want to consider upgrading to the latest version of the toolkit (version 1.1.2) to see if that fixes the problem. I just checked, and apparently this version isn't listed in the online Upgrade Advisor yet, so you would need to contact your NI salesperson to get a copy sent to you. The 1.1.2 upgrade is free for users of RGT 1.1 or later. If things still don't work after upgrading to RGT 1.1.2, I really can't think of anything else to try short of uninstalling everything, then reinstalling LabVIEW, followed by RGT.
Good luck,
-D
