repack values or portion of values
Hi Jeff
I do something near but I need the statistics at the end not in time
At each 10cm calculates in the data stored in the array de values
Message 11 of 14
(1,117 Views)
simple enough
You probably should wire "Sample Length" to Quotient and Remainder Smiley Wink
"Should be" isn't "Is" -Jay
Message 12 of 14
(1,101 Views)
Hi Jeff
Nest week I will experiment in really conditions, seems this code will be what I want.
Very very thank you.
Best regards
cp
Message 13 of 14
(1,091 Views)
Hi Jeff
After some upgrades in software I need your help again
You can see the explanation in front panel
But the laser reads from 0 to 10 cm.
For calculations I need the max value from 0-5cm, the max value from 6-10cm and the average from 0-10cm.
The code almost works, the probelm is that it calculates each 5 cm, and I need only each 10cm, I need to keep the max 0-5cm for the end calculations at 10cm
Formula = (max0-5cm + max6-10cm)/2 - average10cm
Hoppe you understand
best regards
cp
Message 14 of 14
(1,062 Views)
