You can add the following line to the yourapplicationname.ini file that gets created when you build the application:
showTipStringsOnFPControls=False
If you don't want to go through all your controls/indicators and remove the tips.
Programmatically the property is accessed using the VI Server functions (in the Application Control category):
Message Edited by smercurio_fc on 03-30-200601:17 PM
