remove subpalettes
Hi Peter,
in a "normal" system you can make these steps.
1. you see no delete function in the subpalette to remove
2. uncheck the "Synchronize with directory" menu in the palette above (for the subpalette where you want to remove something)
3. the delete function is now available
Hope it helps.
Mike
Message 11 of 15
(2,086 Views)
Hi all,
I, too had problems with this and figured out the arcane two step process for removing many unwanted subpalette. A little clarification is needed. The "Synchronize With Directory" item does not need to be selected for "Delete Subpalette" to be missing.  See attached screen shot. Two approaches may remove the subpalette. The first is to simply unselect "Reserve Spot for Synch Item" (assuming it’s selected). The second is to select "Synchronize With Directory". At this point, LV should ask for a directory to sync with but it does not (as if the item was being deselected). Then right-click again and the "Delete Subpalette" item will be available.
I have been unable to remove some subpalettes regardless of what procedure I try. For instance, the 'Control & Sim' and 'Vision/Motion' palettes can't be removed.
This sure feels like a bug... I'm using LV 2009 so it hasn't been fixed yet.
Bob Albern
Message 12 of 15
(2,031 Views)
This is still an issue in LabVIEW 2013. However, Bob_Albern's workaround solution still works.
Message 13 of 15
(1,601 Views)
From the menu on any block diagram select  View>>Functions Palette.  This brings up the Fn Palette with a "Customize" link on the top.
Hit that customize!  the third selection down is "Change Visible Palettes..."  Select that and you get this dialog:
Just deselect "Express" (or any catagory that otherwise annoys you) and Bob's your uncle.
A similar approach is available from any FP Menu>>View Controls Palette to modify Control catagories displayed so you can dump those express controls and the super-ugly classic controls too!
"Should be" isn't "Is" -Jay
Message 14 of 15
(1,587 Views)
That seems to only work in the root palette.
Message 15 of 15
(1,585 Views)
