I have a whole bunch of controls, but I only want a few of them to be in the tab sequence. How can I remove the others from the sequence? I would still like the users to be able to manually select the control and edit it; just not be able to tab to it.
I too want to do this but I have indicators that I want to remove from the sequence (Waveform Chart, Error Cluster, strings...)
There is no Key navigation tab on the properties page for these Items. How do I get around this problem please? (Some of them are not even on the displayed part of the screen at runtime.)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Obviously,the Skip this control when tabbing property is not available for indicators. They are skipped by default. Press Ctrl+M to switch the VI to the run mode (or run the VI) and then press Tab to convince yourself. Press Ctrl+M again to switch back to the edit mode.
