01-15-2020 08:54 AM
Hello, my aim is to design a VI whereby i could demonstrate the effect of varying the load and its effect on the power generated and vice versa. The best i could do so far is to merge them into one chart. My issue is that i dont know how to bring in the conditions necessary for each plot and the effect it will have on the other. p.s: in the first case, i will keep power generated constant and will vary the load and in the second case, the power generated will vary and load will be kept constant (Surges or spikes occurance). I would be really grateful if someone could provide me with some guidances or help.
01-15-2020 09:38 AM
Are you wanting to simulate this or are you going to be using actual instruments and doing it?
01-15-2020 10:46 AM - edited 01-15-2020 10:46 AM
Its a simulation. This is the best i could do. Im trying with varying only Pload. When Pload> PCoal, Pload will drop to zero. Any idea what i could use to meet these conditions?
01-15-2020 11:08 AM
I would make an array of Pload and feed that into a FOR loop. Do whatever math you need inside of the loop and autoindex the values out. Then you can build up an XY Graph to show the relationship.
01-15-2020 01:28 PM
