03-16-2010 07:47 AM
I also had errors but they're not rounding errors. Don't forget to call the setmixdll and the setrefdll.
Attached you find an example for the phflsh-Subroutine in the RefProp.dll (input values: p, h; output values: T, cp, cv, speed of sound, entropy...). With the attached llb you can build your own VIs.
Philipp
06-23-2010 12:17 PM
I am trying to generate enthalpy values in labview using refprop based on a temperature and pressure input. I have been working off the examples posted on this fourm however, am unable to get them working. I believe it has something do with my directory but I believe i have them set correctly. I am recieveing and error out 8 : Open File. With a possible cause relating to not having permission to open the file. Anyone know what I am doing wrong? Thanks
06-24-2010 03:39 AM
Hello bshelly,
maybe you need administrator rights?
Attached you find your VI and a manual.txt for using RefProp with other programs.
Here's what I did (since I'm using the german version, I had to translate the commands. So maybe the terms are wrong):
Open "Example for phflsh.llb" --> open Test.vi --> enter block diagram --> double content of right frame --> change caption and input values --> enter "Two phase ph-flash.vi" --> Save as new copy "Two phase tp-flash.vi" in "Example for phflsh.llb" --> close "Two phase ph-flash.vi" --> edit vi symbol --> enter block diagram --> double click "Call Libary Function Node" --> since "enter path in block diagram" is checked, you cannot change the dll function. Uncheck it and browse the path to RefProp.dll --> Look for TPFLSHdll in the drop down menu --> check "enter path in block diagram" --> go to parameters. Here you can see the input and output values --> change the order as you can find it in the manual.txt (subroutine TPFLSH (t,p,z,D,Dl,Dv,x,y,q,e,h,s,cv,cp,w,ierr,herr)) --> OK --> from "Initialize Array" delete the lower cable and make a new connection with the slot above the upper one --> enter front panel --> right click the output cluster --> "Rearrange elements in cluster..." --> choose the same order as in manual.txt --> in Test.vi block diagram replace the "2 phase ph-flash" with the new "2 phase tp-flash" delete the indicator and copy/paste it from "Two phase tp-flash.vi" --> start the VI --> all calculated values (density...) should be identical.
Hope that helps
Philipp
06-26-2012 09:05 AM
Hi DrHoas,
Are these vis that you attached at the previous thread just for mixtures? I want to calculate isobutane properties for given specific state points. Can I do this with this ones? If I could not, how can I do this? I read and find a series of vis from NIST web site but I really do not how to prepare a vi with them. I will appreciate if you answer to me.
07-02-2012 03:39 AM
Hi newbieeng,
attached you find a llb for several calculations. Just enter your path to RefProp in the "Init and Calc RefProp.vi". That should work. You can also use the VIs for pure refrigerants (e.g. R134a without file extension but R407C.mix with file extension). For comparisons with the RefProp GUI note that the output clusters are in mol.
Philipp
07-02-2012 03:57 AM
Thank you very much Philipp.
04-12-2016 09:15 PM
I hope that you are doing fine.
First of all, I followed this thread and finally managed to get Refprop working in LabView. Thank you.
Please view the attached Refprop.png file, that shows that how I have used 'R calc' and 'R int' to calculate the fluid properties. I used the files mention on this website. http://www.boulder.nist.gov/div838/theory/refprop/LINKING/Linking.htm#LabViewApplications.
I a beginer in Labview. Currently I am using NI USB 6001 to read pressure and temperature from my instrument. I am interested to calculate the viscosity of Nitrogen gas based on the pressure and temperatrue (real time calculations) .
Problem: As you can view from the front panel. png that this program is calculating properties of nitrogen gas, but not calculating the dynamic viscosity (Pa.s). Could you please let me know how can I calculate dynamic viscosity ? which files I need to change ? I am using the same files that are available in link that I mentioned above.
Thanks a lot.
Syed
07-07-2016 12:38 PM
Thank you for this information on how to use Labview together with Refprop.
Can anyone tell me how to add a variable to the Labview VI that was posted earlier in this thread ? For example if I do a P,T flash using the Labview VIs posted here I can get the pressure, temperature, enthalpy, density liquid, density vapor, entropy, internal energy, quality, speed of sound, Cv, and Cp.
But how can I get the viscosity ? How do I modify the VI to give me extra parameters like for example the viscosity ?
Any tips would be appreciated.
Thank you
07-07-2016 04:10 PM
I finally manage to get the properties of Fluids in labView, procedure is lengthy but quite simple to do.
1) Installed matlab on my computer.
2) Installed Refprop on my computer (http://www.boulder.nist.gov/div838/theory/refprop/MINIREF/MINIREF.HTM )
3) Connect Refprop with Matlab (http://www.boulder.nist.gov/div838/theory/refprop/LINKING/Linking.htm#MatLabApplications). By doing this you should be able to call Refprop in to Matlab. If you can do it, then next step is fairly simple.
4) Afterward, call the matlab script in labView. Function>Mathematics>script and formulas>script nodes> Matlab script. Or simply search in funtion "Matlab. By doing this you will be able to do what ever you can do in Matlab.
I am currently using it. It is faily simple.
Let me know if you stuck some where.
Syed
07-07-2016 09:46 PM
Hi Syed,
The links are not opening. Are they the right ones? Please confirm.
