07-17-2009 04:37 PM
Does anyone know if there is a way to place a reentrant vi in a for loop and make each iteration of the loop call a different instance of the vi? Currently it seems the behavior is to automatically assume that each loop iteration should re-use the same instance of the reentrant vi, which usually seems to make sense. I just wish there was a way to change that behavior for certain circumstances. My current issue is that I have a reentrant vi that I need to run 18 times, but each of the 18 instances must save its state separately for the next cycle. It would be nice to put this vi in a for loop instead of dropping it 18 times on my block diagram. I dont want to get into the gory details of why i need 18 independent copies, but I do.
Feature request?
07-17-2009 07:20 PM
07-17-2009 07:48 PM
07-18-2009 03:45 AM
Another two options:
Good luck,
Ton
