05-31-2007 10:00 AM
05-31-2007 10:24 AM
05-31-2007 10:34 AM
05-31-2007 11:07 AM
is it possible that you are using a compination of opening a template vi that is reentrant or includes a reentrant subvi. This is just a guess. But the cloning usually refers to opening a template (clones the vi).
Paul
07-01-2008 09:57 AM
Hi there,
I'm using LabVIEW 8.01 right now and after modifying a reentrant vi (amoung others) and then hitting "Save all", I got this "Reentrant data space could not be cloned!!" popup. I hit the "Save all" again and no popup appeared. Any ideas why the popup appeared? I have a nasty feeling it will re-appear at some stage.
-Martin
07-02-2008 03:51 PM
06-20-2009 02:14 AM
Stephen
Even after compiling in same version also i am getting the prompt " Reentrant data space could not be cloned" And LabVIEW getting closed automatically after that message.
What else could be the issue?
Guna
06-22-2009 05:23 PM
Hi Srinivas,
What version of LabVIEW are you using? It is also possible that this is a bug that has been fixed in later versions of LabVIEW. Let me know the version number, and I will look into if this is a known issue.
Stephen S.
