01-30-2007 02:23 AM
01-30-2007 02:54 AM
Reentrant VIs only had the option of having a seperate FP for each panel in LV 8.0 or 8.2, so you can't do that in 7.1 anyway.
What you want to do is change your VI to a VI template by changing its extension to .vit. This will make LV generate a new copy of it whenever you open a reference to it. I believe you can see examples for this in the example finder (Help>>Find Examples) by searching either for "subpanel" or " template".
01-30-2007 03:21 AM
01-30-2007 03:54 AM
01-30-2007 04:01 AM
I'm not entirely sure what you're trying to do, but a global will probably not help since all the VIs will call the same global and you will have a race condition.
Did you look at the examples (specifically, the one called "Templates")?
If the examples don't help you, I suggest you upload your code (preferably in 7.1) with a clear explanation of what you want to do so that someone can help you.
01-30-2007 04:07 AM
01-30-2007 05:36 AM
I feel like we're going in a loop.
01-30-2007 08:18 AM
Hi Bartb,
Please take a look at the example code I posted in this weeks Nugget
http://forums.ni.com/ni/board/message?board.id=170&message.id=226491#M226491
In that example I pass values to VIT's before I start them.
Ben
