07-13-2010 05:53 PM
i did reinstall the USB create thing many times
so with that in mind, how do I solve the "corrupt software?"
07-14-2010 10:44 AM
Re-install Windows.
07-15-2010 02:28 PM
ok now funny thing is i followed your steps, still same message
now what? so far you told me to reinstall windows, did that, still the same problem and issue, another way to solve this?
07-16-2010 11:33 AM
Is this a PXI RT Target? The following two KnowledgeBase articles may be helpful.
Diagnosing Hard Drive Failures for PXI and VXI
http://digital.ni.com/public.nsf/allkb/E15AAB42FD3B625E86257111005E3CFF?OpenDocument
Why Am I Unable to Format My PXI-RT Controller from a Desktop PC Utility USB Drive?
http://digital.ni.com/public.nsf/allkb/21B9C3C367941A2B862575FA004E3ED7?OpenDocument
Best,
Chris LS
07-16-2010 11:41 AM
both the computers that i am using, mother and target are both desktops, again, on the target computer it said gave that error message that is described in the previous entries of the posts
i reformatted the hard drive because tbob told me too. so what are my options now i am really desperate!
07-16-2010 11:50 AM
Are you trying to install the LabVIEW Real Time O/S to this PC? Where do you see this corrup disk error? How are you formatting the disk at the moment?
Best,
Chris LS
07-16-2010 12:07 PM
On which computer are you getting the error booting from hard disk message. This message can only have three causes: corrupt software (fixed by re-install - this evidently is not the case), a bad hard drive (you probably could not even reinstall anything if the hard drive is bad), or a bad motherboard. Is the problem on your RT system or your development system? Which RT O/S are you using. Which windows development O/S are you using?
07-16-2010 12:16 PM
Best,
Chris LS
i am trying to only install using the USB create, i am seeing this message on the target computer, i am using the usb to format using the usbcreate exe thing
07-16-2010 12:18 PM
i am getting the error on the TARGET computer, the problem in on my RT dedicated computer, i am using 9.0 RT OS, windows development..hmm..XP?
07-16-2010 12:19 PM - edited 07-16-2010 12:19 PM
What is USB Create? Does that re-install the real time operating system on the target computer?
