11-03-2014 12:34 PM
The numbers in the file is a bit random, when running the whole system we will send one 4-bit number at a time. (Corresponding to 1-F so 16 different numbers in total.)
So for example if we sent 3, the input file would be lots of zeros then 0,0,1,1. We will probably implement another 1 before the number as well so the computer know when to "start recieving". (We are supposed to send from one computer and recieve with another so we would have to do something like that.)
This looks really close to a solution though, the only problem left would be to make it "start reading" when it recieves the first 1. (And also to not include that one in the number displayed..) Thanks alot! 🙂
11-03-2014 02:33 PM
Okay so I think Ive almost figured it out now with the help from you guys! 🙂 Just one last thing:
Does anyone know if its possible to put all the values on one row instead of one on each somewhere in the process? That would solve the entire thing for me!
Thanks 🙂
11-03-2014 03:00 PM
Tobf wrote:Does anyone know if its possible to put all the values on one row instead of one on each somewhere in the process? That would solve the entire thing for me!
Thanks 🙂
Your program makes very little sense.
Why don't you read it as integers since you are throwing away the decimal digits anyway?
Now you have an array of single digit strings (0 or 1) that you can concatenate into a string of 0, 1, for example.
11-03-2014 03:00 PM
It should be pretty easy to place them all on one line, simply remove the EOL or equivalent from the string. It may take some fiddling to get the correct delineator (EOL, CR or NL) but shouldn't be too hard.
Of course the easier way would be to simply write all of your data to the file as a single long string or use a binary data file.
Might I recommend the "Write Binary File.vi" and "Read Binary File.vi" examples in example finder (Help->Find Examples)
11-04-2014 02:42 AM
Working as intended now with this fix! Big thank you for the help guys 🙂
