06-10-2009 09:59 AM
Could anybody please tell me how can I read waveform from TSD 5052 to pc?
I am using LabVIEW 7.1. What do drives and VIs I need to have?
Thank you in advance.
Nayporn
06-10-2009 10:22 AM
You can use either the LabVIEW Plug and Play or IVI driver here. Unless you really need IVI capabilities, I would recomend the Plug and Play driver.
What other software you need will depend on the connection type and the driver you use. The download page for the driver will list the requirements. You have not provided the type of physical connection you have. If you are using GPIB, then you will also need a GPIB controller, cable, and driver for the controller.
