read ttl with NI9205can
I would like to read a TTL signal using a NI9205 ADC.I've tried different way but no success.
I'm looking for tracks.
Thank you
Message 1 of 8
(2,347 Views)
Hi gustutu,
your 9205 module is able to read voltage signals, so you just read your TTL signal as voltage.
You should get values of <0.8V (LOW) and >2.4V (HIGH). To get boolean values you just compare your voltage signal with a threshold value of 2.0V…
using LV2016/2019/2021 on Win10/11+cRIO
Message 2 of 8
(2,342 Views)
Ok but at the end i have a loop with a value wich is 0 or 1 but i have to detect the frequency of the signal.
Message 3 of 8
(2,336 Views)
Hi gustutu,
Don't know what kind of loop you have and why you only have one (1) value of TRUE/FALSE.
Source code (aka an attached VI) would be helpful here…
You should read more samples with a higher samplerate - obey Nyquist when you want to determine frequencies!
Message 4 of 8
(2,329 Views)
Message 5 of 8
(2,323 Views)
Hi gustutu,
so you read "one channel, one sample" and expect to determine frequencies from just one sample?
LabVIEW comes with alot of example VIs, just study them!
Message 6 of 8
(2,319 Views)
i 'v already tried with this multisample but this ****** vi stop the programm if the signal is 0
Message 7 of 8
(2,313 Views)
Hi gustutu,
what have you tried?
What is a 6-star VI?
Why should it stop when the signal is 0?
Message 8 of 8
(2,294 Views)
