Reply
read text file in myRIO
I did reading a text file in LabVIEW.But when i did in LabVIEW MyRIO ,it shows error7.Please help me with this
Message 1 of 10
(811 Views)
So is the folder and file on the myRIO?
Message 2 of 10
(805 Views)
Error code 7 is "File Not Found".  So use WebDAV or FTP to put  your text file where you expect it to be.
Message 3 of 10
(793 Views)
.Yes,I had saved both the file and the text document in the folder containing LabVIEW
Message 4 of 10
(785 Views)
Thankyou Sir,I will work on it
Message 5 of 10
(784 Views)
Folder containing LabVIEW?
Is that folder on the myRIO?
I don't know what LabVIEW folder you are talking about.
Message 6 of 10
(770 Views)
Accepted by topic author riah1920
02-02-2018 04:12 AM
in case this is not clear yet, your myRIO-VI is not running on your development machine,
so any file references must be local to the myRIO file system structure.
also you have to make sure you are in a read/writeable directory for the 'lvuser' ( i am guessing that myRIO and cRIO run the same linux), but that should be if you move your files via webdav/ftp onto the myRIO.
i did use the "/c/" path and created a subdirectory there, for file writes from my VI.
also, move the file open and close outside the loop, unless you really need that, like changing the file or something while the loop is running.
* http://zone.ni.com/reference/en-XX/help/371361N-01/lverror/misc_lv_error_codes/
* http://zone.ni.com/reference/en-XX/help/370622N-01/TOC38.htm
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 7 of 10
(767 Views)
Thankyou so much Sir,I was able to get successful results
Message 8 of 10
(742 Views)
glad i could help out
Message 9 of 10
(738 Views)
if you have an active subscription, i recommend you to take the two real-time courses.
http://sine.ni.com/myni/self-paced-training/app/main.xhtml
Message 10 of 10
(731 Views)
