08-03-2012 09:57 AM
I am unable to read or write to a FPGA I/O Node. The write is greyed out.
Solved! Go to Solution.
08-03-2012 10:06 AM
1. Do you have LV FPGA installed?
2. Are you in a LV FPGA project? (this is my main guess)
08-03-2012 11:02 AM
Have you assigned any physical channels to the project?
08-03-2012 11:38 AM
yes to both questions..I can drop a FPGA I/O fine but when I got to wire up a boolean the line is broken
08-03-2012 11:39 AM
yes, they even show up in the FPGA vi
08-03-2012 12:33 PM
What does the error say when you hit the "Run" arrow (or hover over the broken wire) after wiring to the IO node?
08-03-2012 01:11 PM
Are the DIO module's channels set to write? You need to go into the properties for the module and select this. Find the module in the project, right-click and choose properties. I don't know which module you have, but if it's 8 channels you can usually do it in groups so you can set channels 0-3 to read or write, and channels 4-7 to read or write. But, you can't have each individual channel have it's own settings, just FYI. Although, this may be different on certain modules.
I would suggest looking at the settings.
08-06-2012 06:02 AM
Here is a screen capture.
08-06-2012 11:52 AM
Looks like the cluster isn't carrying the IO Item information properly. Can you attach your project (including all FPGA VIs), showing how you're bundling that cluster?
08-06-2012 01:08 PM
It was as Nathan had said. When I cut and pasted the FPGAI/O from another project the links to the Target were broken. I had to delete them in the project, recreate them then link them to the connector.
Thanks..
