To use this card from LabVIEW you need to have the NI-DAQ driver installed. Once the driver is installed, in LabVIEW select the functions palette from the diagram and go to the Data Acquisition subpalette. Here are all the VIs to program your hardware.
Christian L
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
