read from spreadsheet to array of strings
Hi
I need help to build a 1D(string) array from a MS Excel file. I've tried using read from spreaaadsheet/ read from Meaurement file. I'm unable to do this. The excel file contains alpha-numeric data. please suggest with some example vis.
input would be the excel file path
output would be a 1D array of strings
Thank you
Message 1 of 8
(4,627 Views)
Accepted by topic author Mayur_VIenthusiast
Is it necessary to be an Excel file or you are using Excel to open the file?. If it has to be Excel then you may have to use the Active X (Example you can find in this board), otherwise just save it as csv file and use the Read from spreadsheet vi with "," as delimiter.
Message 2 of 8
(4,619 Views)
hi i've updated the program. i'm getting an output but, the output array comes out as comma delimited elements. how do i seperate them??
Message 3 of 8
(4,595 Views)
For reading excel
Message 4 of 8
(4,586 Views)
muks, this program doesnt work for strings
Message 5 of 8
(4,569 Views)
How do you say it doesn't work?
Message 6 of 8
(4,567 Views)
You must give the delimiter as "," (comma) while using the Read from spreadsheet vi to read the file.
Message 7 of 8
(4,566 Views)
Thank you
I'm posting the completed VI for others reference
Message 8 of 8
(4,546 Views)
