02-11-2009 07:15 AM
02-11-2009 07:25 AM
Questions:
1) Does the device show up as a drive-letter in the OS?
2) Is the device part of the "Mass Storage" USB Class?
3) Are you familiar with low-level USB communication?
If the answer to 1 is YES then simply write files using the normal "Write file" function.
If the answer to 1 is NO then I strongly recommend (assuming the answers to 2 and 3 are YES) you look at THIS Page under "Mass Srtorage".
I don't know anything about Mass Storage commands myself except for the fact that it should be possible with VISA Read and Write (Bulk communication). As to Filesystem and / or ATAPI comands or such, can't help you there I'm afraid.
Shane.
02-11-2009 08:04 AM
Hi Shane,
Thanks for the reply, and the tips. I will read it soon.
Attached a snapshot from the code when I run it.
Regard
Guresha
02-11-2009 08:12 AM
First: that's not a picture of the code, it's a picture of the front panel.
Second: you're obviously dealing with a device which has flash memory internally, not directly with the flash memory itself. That's a whole different thing.
Third: check the manufacturer's documentation.
Shane.
02-11-2009 08:35 AM
Hi again,
Sorry, I ment the picture of the front panel.
I attached the code at the first post, but I can attached again.
as you said the device has an internal flash memory and can be stacked together to extend the data memory to 64G.
Guresha
02-11-2009 08:40 AM
I don't have 8.6 so I can't open the code. Sorry.
Does the manufacturer deliver documentation for communication?
Shane.
02-11-2009 08:59 AM
Hi Shane,
It is serial for communicating with RS232.
Regard
Guresha
02-12-2009 02:00 PM
