02-06-2015 12:45 PM
02-06-2015 01:29 PM
02-06-2015 01:30 PM
Pretty much as can be seen on this picture (I do not read the entire file in one go, that is the difference) :
02-06-2015 01:33 PM
I also tried to read a spreadsheet instead of a F32 (but I'd rather have it as a F32), but somehow I do not know how to change it in labview ... error below, same code place
02-06-2015 01:38 PM
Post your data file, those pictures do not really help. If you can not figure out a way to zip it, change it to .txt or something else then create a simple VI using Read From Binary File to read the file into a string indicator. Set the string indicator to hex display, copy and paste several lines of the hex data into a reply here. I have stared at enough binary data that I wager I could look at it and tell you the format and how to read it.
02-06-2015 01:40 PM - edited 02-06-2015 01:42 PM
Well, that's quite different. Did you check the values before jamming them into the variant at the invoke node?
How big is the file? have you tried setting the size to -1?
Please make an atomic little VI that only tests the file IO. No need to drag along all that extra code for now. Then please attach the actual VI and datafile in a zip file (use a different browser if you have problems!).
Images never tell the full story. For example we cannot tell if the orange diagram constant is really SGL or something else. We need the VI!
02-06-2015 01:46 PM
Here you go, sound file in zip format attached, I changed browser indeed thanks for the tip. I'll try to make a mini VI I-O as you suggested, thanks for your support!
02-06-2015 01:53 PM - edited 02-06-2015 01:53 PM
02-06-2015 01:58 PM
Agreed, strange. Thanks!
02-06-2015 03:18 PM
