read data from file fro HP4192A
I think you will have inconsistent results until you fix the command. Instead of removing the % variable, replace them with constants.
Message 11 of 13
(776 Views)
The result is excellent when I run the program on “Highlight Execution” mode. But there are some problems when I run that on normally mode. It is waiting for a long time (about 30 seconds) on some points when it is reading. Then it is putting zero values to all of three displays.I couldn’t see what it reason. I don’t know how I can replace the command string with constants. I attached read&write.vi , read.txt and write.txt file. Please examine the write.txt file to see what I mentioned situation. Thank you so much, again.
Message 12 of 13
(749 Views)
Accepted by 960310
I solved the problem at the end with your greatfully helps. thank yo so much.
Message 13 of 13
(698 Views)
