read a measurement a file
Hi G.,
can you also attach a TDMS file you created with your VI? (ZIP it before attaching…)
Message 11 of 20
(2,205 Views)
Yes that's the problem I'm trying to solve because I want all for data for all the windows, and I'm stuck since last week, I advance about my work but every time I am confronted with this problem.
And I can not find a solution ...
Message 12 of 20
(2,201 Views)
- Download and install the DataPlugin for TDMS from ni.com/dataplugins.
- If you use "Convert TDM to TDMS.vi", one of the first subVIs has the string "TDM" wired to it. Replace that with "TDMS".
- Put the whole thing into a loop that loops over all your source files and writes to the same target file.
Please note that depending on how you want to concatenate your data, you might have to do some additional tweaking here and there.
Message 13 of 20
(2,198 Views)
Here is my file tdms
Tank you so much
Message 14 of 20
(2,197 Views)
try something like the vi that i have attached
Message 15 of 20
(2,189 Views)
I work on labview 2014, you can put on this release please. The file version is too recent that my version. Thank you!!
Message 16 of 20
(2,182 Views)
Hello, I hope you have no forgotten me
Message 17 of 20
(2,157 Views)
hi,
attachement is labview 13 version..it will do..
go through some labview tutorials on writing file to get better understabding of this....
There are  two ways to tell s thanks in forums : either give Kudos or  Marked Solutions
Message 18 of 20
(2,153 Views)
thank you but there is an error in the output of the "read tdms". I do not understand why it is not able to read the windows.
Message 19 of 20
(2,146 Views)
hello, I'm sorry but what you gave me as an example, that does not work, it does not recognize the windows....
Message 20 of 20
(2,109 Views)
