12-05-2016 04:46 AM
firstly, i hope i am posting this to the correct Location.
I need help with channelising a plan that i have with regards to usage of Digital I/O.
I heed to use 2 X digital I/O cards (third party for whom labview driver is available. Need to use two cards because of the number of output channels that i want to randomly toggle).
Is labview the best option?
What programming language would i need to use?
would labview support two cards?
12-05-2016 04:50 AM
Hi RAM,
As you are asking in a LabVIEW forum: YES, definitely! 😄
What are the alternatives?
LabVIEW for obvious reasons… 😄
What are your alternatives?
Yes. Even more than two! (If the driver supports this…)
12-05-2016 05:06 AM - edited 12-05-2016 05:11 AM
thanks for the reply, is there a trial version of Labview that i can work with, which would support the digital io cards?
Any good tutorials available for achieving this task?
12-05-2016 05:36 AM - edited 12-05-2016 05:37 AM
Hi RAM,
Ask the manufacturer of your IO cards for drivers. (You already said there's a driver available!)
12-05-2016 07:43 AM
You probably are.
Out of curiousity, how many channels? Tell us about your device.
What does "best" mean to you? LabVIEW should provide a reasonable platform for quickly developing code to test your device and see if it performs according to your needs.
You have told us very little about what you plan to do, other than it involves "random" (in time? in bit position?) "toggling" (does this mean turning on and off, i.e. producing a pulse of known width, or turning on or off, producing pulses of "random" width?) the output channels (independently? synchronously?)
Depends on the cards and the drivers, which are unspecified. LabVIEW can definitely deal with multiple devices "simultaneously", provided their drivers don't interfere with each other.
One of the reasons it is difficult to answer your question is that you have not outlined what you plan to do, including specifying the time scale (are we talking seconds between transitions, or transitions in the MHz range?). Are you planning on doing the LabVIEW coding yourself, or hiring someone with LabVIEW Experience? If you are doing it yourself, do you have experience in LabVIEW? If not, are you an expert in some other programming paradigm?
01-03-2017 03:29 AM
hello
well it is a 96 channel Digital IO card manufactured by ICP DAS.
what i mean is, 3 channels would be grouped, and a change in logic level in one of the channels, of the group, will act as a trigger. The frequency is expected to be from 1Hz to 10Hz, and needs to be configurable. Getting back to the frequency, i would need to move from a group to group when it comes to changing state, and this would be random, upto a maximum of 10 Hz. I need to use 2 cards, so that i can have more groups available for the test setup.
i intend to use the labiew coding my self.
I have a question with regards to Measurement and Automation Explorer, i dont seem to be able to see my device under 'Devices and Interfaces'? My hardware is plugged in, the device can be see as part of DAQ devices, in control panel, and a test utility running on labview recognizes the card. I have tried to right click on 'Devices and Interfaces' , but nothing can be done. Should i be concerned about the MAX behaviour, or can it be ignored?
01-03-2017 03:39 AM - edited 01-03-2017 03:41 AM
Hi techie,
Please show relevant screenshots of your MAX window…
Where do you "see" your device?
Which "control panel" are you using?
Which "test utility" are you using?
When I right-click "devices and interfaces" in MAX I can choose "New…"! You can't?
01-03-2017 04:06 AM
please find the card visible in the windows Control Panel utility (card_controlpanel.png)
also find a snip of dio application that i am using (dioapplication.jpg)
screen shot of what i see in MAX (max.jpg)
01-03-2017 04:09 AM - edited 01-03-2017 04:13 AM
Hi techie,
NI MAX is used to configure NI hardware.
You are using a "UniDAQ PIO-D96", apparently from a different manufacturer.
Are you spotting any problems here? (I made some words bold to assist you! :D)
You should got a manual for your device. You seem to have a LabVIEW driver for your device.
What else do you need?
01-03-2017 04:18 AM
sounds good, therefore i dont need to look at MAX.
well, some leads on how i can start with generating logic level changes on a channel, followed by generating random channel selection.
