ramp voltage generation
I want to generate a simple ramp voltage. The inputs would be start ramp voltage, end ramp voltage and the ramp rate. Is there any pre defined VI or should we create one.
(3,879 Views)
Accepted by RavensFan
Did you search the palettes or tried Quick Drop? You would have found Ramp Pattern.
(3,877 Views)
Thanks for the reply. Yes I did search. There is ramp voltage.vi but it has instrument handle which i dont know much about. I want a simple ramp voltage generator
(3,838 Views)
There is also a ramp voltage generator which require samples as input. I do not want samples as input to the ramp generator
(3,830 Views)
So what is the problem with using the function I mentioned? It generates an array of values per your requirement. Whatever hardware you are using would interpret it as voltage. You just pass the array to a for loop. What hardware are you using?
(3,820 Views)
Yes i tried using ramp pattern vi and it worked. Thanks.
(3,808 Views)
