"user" colors in color picker
Is it possible to personalize the "user" colors in the Labview color picker (see attached picture) ?
thank you !!
(3,077 Views)
Accepted by topic author haha1234
LabVIEW -> Tools -> Options... -> Environment -> Colors -> Custom Colors...
(3,055 Views)
thank you, I works for the application in Labview environment, but the user colors are empty after I compile the application to distribute it... 😞
Is it possible to specify the user colors for the .exe build of my application ?
(3,047 Views)
the colors are saved in the LabVIEW configuration file (LabVIEW.ini) under the key colorUserItem.
I would try to add this key in the applications configuration file, but I am not sure if it will work.
UliB
(3,038 Views)
