"selected item" in a listbox
HI
I look in the examples about this and I found the solution, which is in the picture atached, but I can´t find this "selected Item" indicator, the only way to use it is to copy and past from the example, is really annoying, I have been looking for this for 2 hours but no luck, and in the help don´t say where I can find it.
any help?
thanks
(1,667 Views)
The 'Selected Items' indicator is an array indicator, which you cant find in the pallettes.
Instead, you ve to make it by placing an empty array containerin teh FP, and then putting a Numeric indicator from the Controls pallette into that Array container, and then changing its datatype to I32.
Try this out...
- Partha ( CLD until Oct 2021 🙂 )
(1,660 Views)
