I have an LV in 6.0. When I press the RUN button a "pop up" window appears. When I key in the required information, I cannot find the RETURN and ABORT button. This is because they are out of view. I have no choice but to restart the PC. How to put the RETURN and ABORT button in the "pop up". My resolution is 800x600.
I'm not sure what you mean but it seems to me that you just have to resize your front panel manually and then save it.
Thomas
Using LV8.0 -------------------------------------------------------------------- Don't be afraid to rate a good answer... 😉 --------------------------------------------------------------------
