"next file" select in path box
Hi, I'm writing a VI that will, amongst other things, read data from a text file stored on my computer and display the information therein on a graph. I have many data files stored in one folder and instead of pressing browse and selecting the next folder over and again I'd like a button that will automatically select the next file in the folder with one click. What is the best way to do this? I have attached my VI so far
any help would be much appreciated
philip
(1,888 Views)
Hi philip,
in the file palette you will find a function named "List folder". That way you get all the files in the selected folder and can so use a loop to iterate over all the files. You may even apply a filename pattern...
(1,887 Views)
