"Variant To Data" VI converts date/time inaccurately.
Why not just round the resulting timestamp to the nearest second?
And if you need to store milliseconds in the database, since the database can't handle that resolution, store the fractional seconds in a separate field that you add to the timestamp once it has been rounded to the second.
Message 11 of 18
(1,980 Views)
How can i round a timestamp to the nearest second?
I haven't found a VI for that.
Message 12 of 18
(1,979 Views)
Round to nearest in the numeric palette.  It works on timestamps just as well as floating point numbers.
Message 13 of 18
(1,974 Views)
I think it would do.
Message 14 of 18
(1,964 Views)
I have a similar problem .I am inserting timestamp values to an SQL database. The problem is when I make the conversion To Variant before insert the data I am loosing the millisecond value of the timestamp.
For example: Timestamp value = 6:48:39.578 AM 10/21/2010 but after the To variant function I get 6:48:39.000 AM 10/21/2010
Message 15 of 18
(1,907 Views)
Losing NOT "loosing".
As early posts said, the database won't take millisecond values.  To round down to the nearest second, and store the millisecond part of the time in a separate field.
Message 16 of 18
(1,900 Views)
I have a similar problem as TinoMK.
The SQL Database does support time in milliseconds.
But when i convert the data from'Date/Time' to a Variant that can be read by DB Tools VI, i loose out on all the info about milli seconds.
See attached Files -
File 1 - Milliseconds allowed in SQL DB
File 2- My Prog
Details - The program tries to capture value from a sensor (here the counter value 'i'), along with the current dat/time. The data to be recorded in a SQL Database (Time + SensorVal) is made into a cluster first, then, cluster to variant.
The descrepancy arises in the date/time string in 'output cluster' (which has milliseconds data) vs 'variant' (doesn't have milliseconds data).
So my point here is, even before the data is sent to the database. The information about 'milli seconds' is lost when we convert the cluster to variant.
Please provide some info/solution to this.
File 3 - Screent shot of 'output cluster' & 'variant'
Message 17 of 18
(1,838 Views)
@NishantPatel wrote:
I have a similar problem as @TinoMK.
File 2- My Prog
The DB Tools cut milliseconds as not all databases handles seconds. In this case it's easier to format the timestamp as a string (with milliseconds) and send that, it's basically what the DB timestamp does anyway.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 18
(1,808 Views)
