07-13-2021 04:50 PM
I have been trying to figure out why I'm getting an error in MAX where no VISA resources are being read. I've uninstalled/reinstalled/repaired NI VISA, NI 488.2, and NI Serial as well as repaired the entirety of the LabVIEW software and nothing has worked. These were the main solutions I found on other forums, but I tried others as well like trying to change VISA system settings (After Installing 3rd Party VISA Software NI VISA No Longer Works - National Instruments), which also did not work. I attached a picture of what MAX looks like - it is not reading any device I plug in, and only shows this error if I try to open VISA settings.
I have genuinely exhausted my resources at this point, so if anyone has experienced this and used a different solution please let me know! Thanks in advance!
07-13-2021 08:07 PM
What device are you trying to discover? What versions of NI-VISA, NI-488.2, and NI Serial do you have installed?
My only other thought is to try to reset the configuration data in MAX (Tools->Reset Configuration Data). That will require a reboot.
07-14-2021 07:04 AM
I'm mainly trying to connect to an Arduino Uno (I've downloaded LINX but can't do anything with it until I can read the VISA resource so the COM port is recognizable) as well as a B+K 9801 AC power supply and a KORAD KA3305P DC power supply, but those are less important. I have the most recent versions of all drivers downloaded which NI shows to be correct for LabVIEW 2020. I've already tried the MAX reboot as well, so that's been debunked.
