01-13-2021 11:08 AM - edited 01-13-2021 11:14 AM
@paul_cardinale wrote:
wiebe@CARYA wrote:
I wired a reference to a cluster with 2 elements and no labels. Added labels. LabVIEW hangs. (AdaptToInputs.vi I think).
I couldn't get that to happen.
1) create an empty cluster constant.
2) drop a 1st numeric constant in it (no label).
3) drop a 2nd numeric constant in it (no label).
4) change to control.
5) create reference.
6) wire reference to xnode.
7) extract the xnode (to show 2 outputs).
😎 give 1st numeric control a label ("a").
9) give 2st numeric control a label ("b").
Step 9 hangs LabVIEW for me (18 and 20).
EDIT: the 😎 is free.
01-13-2021 11:28 AM
It's the same when the labels are the same, not just empty.
So, if two controls are labeled "a", renaming the first to "b" and the 2nd to "c", LV hangs too.
Probably the while loop in AdaptToInputs.
01-13-2021 11:37 AM
Also tried to get elements from clusters that come from an array.
This broke the VI.
I tried to insert a " To More Specific", but that hangs LV.
01-13-2021 04:28 PM
Here's the fixed up version.
01-19-2021 08:49 AM
Here's wild bug: I have a cluster in a cluster and I want to get a reference to an item in the inner cluster; so I daisy-chain the XNode.
When I do that in LV 2018, the wire breaks:
However in LV 2019, it works OK:
Then if I take that LV 2019 version and save it as LV 2018, and open it in LV 2018, it's OK:
01-19-2021 03:09 PM - edited 01-19-2021 03:12 PM
If you sprinkle in some Always Copies does that help? I mean it may help but it doesn't really help, unless it also gets fixed by putting an always copy in the generated code.
Edit: I also just tested this in 2018 SP1 with a non-typed cluster, and a type def in a type def and they both worked without a broken wire.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
