‎07-11-2008 04:52 PM - edited ‎07-11-2008 04:53 PM
‎07-11-2008 05:34 PM
‎07-14-2008 06:29 PM
‎07-17-2008 02:19 PM
From what I have learned, there is no direct replacement for the Total Data Size property for use with running VIs. There are two semi-replacements, but neither one has the complete functionality of the former property node.
First, you can gather system information from the command prompt. However, all LabVIEW information is listed under one item. This article explains more.
Second, you can use the memory profiler tool in LabVIEW. Tools » Profile » Performance and Memory
Note that you can also continue to use your LabVIEW 6.1 executable that functions as you want.
I hope this helps,
Kevin S.
‎07-17-2008 03:13 PM
‎07-18-2008 11:40 AM
‎02-08-2010 11:49 AM
Just to mention another user (me) also ran into the same issue (LV 8.6). Help is clear so no time spend solving the bug...
However in my case I am making some (multiple) cache functions and I would like to monitor memory per cache. Not easily possible now 😞
About using taskmanger. There is a .Net example or so included with labview, with a good search you should be possible to find this so at least you can monitor the combined memory consumption.
