03-14-2019 04:05 PM
@Hooovahh wrote:
Listen I can make all the packages we want I just think Paul has several worth highlighting and it might make more sense to have a Paul's Favorite XNodes package which has a bunch of these rather than a package for each XNode. I wouldn't want a palette for each array function for instance. This is a bit larger of a request but one I can still help out with. I'd just need a list of XNodes Paul things is ready for public consumption. I think I can find most he's posted.
If you do that, I will create fake profiles just to give multiple kudos.
mcduff
03-14-2019 04:16 PM
@paul_cardinale wrote:
I'm not sure what you want. This statically references a VI; but there's no such thing as a static reference to a clone.
I think they mean something like this:
In that example I show using a static VI reference to spawn N clones of a VI. For that to be used with Call and Forget you OR 0x40, with 0x80 to get 0xC0. This only is possible if the VI is reentrant, and if the options are set properly. In your XNode they are hard codded to either 0x80, or 0x100. Basically I think the best option to do this would be to add a right click option on your node that ORs with 0x40 if set to reentrant, and then doesn't if it is off.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
03-14-2019 04:25 PM
Side note: the use of 0x40 is widely misunderstood. You don't need it to create a reentrant clone, and it adds needless overhead.
03-14-2019 04:26 PM
@mcduff wrote:If you do that, I will create fake profiles just to give multiple kudos.
That won't be necessary but a Texas tea at NI Week will do
Attached is a package with 3 of Paul's XNodes in them. Very minimal cleanup effort but it has a proper icon for the palettes, and a bit more documentation in the package. Also there was a few VIs named the same and I had to relink to just one copy, they all were the same code. Oh and it is for 2018 because one of the VI sources was 2018 but back saving to 2017 is possible. Earlier won't work since one of them contains a VIM.
03-14-2019 07:00 PM
@EricR wrote:
@paul_cardinale
Are you open to a discussion with me about allowing NI to just ship this code? Either as an example or as a palette add/replacement?
eric.reffett@ni.com
Note that "Start Asynchronous Call" has a property called "Static VI Path", but it doesn't do anything. But this does suggest that a one time, NI was at least considering this functionality.
03-14-2019 07:11 PM
I can find them all :). But not everything in my pile is suitable for sharing. And some of my early XNodes are a bit lacking. But I'll see if I can put together a collection of fun and useful XNodes.
03-15-2019 09:39 AM
mcduff
That won't be necessary -- I'm reasonably confident that enough Forum participants who can appreciate Paul's contributions will be hitting the Kudo button ...
03-15-2019 09:58 AM
Here is Version 2. I remember making the following updates:
03-15-2019 10:17 AM
Here are some others you might like:
03-15-2019 10:20 AM
More Xnodes:
And Index and Unbundle (I never made Help for it. It's the complement of Index and Bundle)
