"Small Font" in LabVIEW 2013/2012 Icon Editor
Dear All:
I have encountered a strange thing recently while using icon editor in LabVIEW 2012 and 2013. I am accustomed to using "Small Font" when editting VI's icon in the Icon editor(LabVIEW 8.0,8.2,8.6,2011), but i found this font in LabVIEW 2012/2013 is different from the one in LabVIEW2011(or 8.6..), the details are as attached images. My question is how can I do to use "Small Font" as I did in LabVIEW 2011, and how to remove the color layers while editting text. any help will be great appreciated.  Thanks very much. Hope your reply……
Message 1 of 21
(6,608 Views)
2011
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 21
(6,604 Views)
Message 3 of 21
(6,599 Views)
Message 4 of 21
(6,594 Views)
What you want to express now?? Is your problem solved or still there is some confusion.. If solved mark as solution...!!
Message 5 of 21
(6,580 Views)
My confusion is that the "Small Font" in My LabVIEW 2012/2013 is annoying.  I want a Small Font in LabVIEW 2012 like the Appearance in LabVIEW 2011(as attached images)
Message 6 of 21
(6,569 Views)
Then do the settings, choose right FONT (Small) and Font size (8 or 9)...!! By doing any changes in the settings, it will not modify any existing text..!!
But after making the changes in the Font setting, next time when you'll try to write any text, either on any of the four lines or by using the text tool, you'll see the text with changed font settings.
Message 7 of 21
(6,562 Views)
I certainly know how to edit a text. the key issue is the "FONT", Please see my attached image.
Message 8 of 21
(6,555 Views)
Accepted by xyl4804
This is a known bug which has been reported (CAR #379054), unfortunately too late to make it into the 2013 release.  It effects Asian localized version of LabVIEW.  It is due to a change in the way the picture control renders text (the picture control is used to display the icon on the icon editor), so will also effect picture control users.
Message 9 of 21
(6,544 Views)
Thanks so much.
It appears that my "Small Fonts" doesn't take effect.
And expecting it will be resolved earier....
Message 10 of 21
(6,536 Views)
