"Read delimited spreadsheed" stops at hyphen in string
Dear LabVIEW folks,
as I am still at the very beginning of learning, my question might seem a bit stupid.
I want to read a spreadsheet and write it to an array.
For this I use the "Read delimited spreadsheed" function.
It works fine, except if there is a hyphen (minus sign) in a string, then the cell is not read to the end.
How can I fix this without changing the original data?
Thank you in advance,
Nortbar
PS: I really tried long to understand the issue, but couldn´t find the answer.
(266 Views)
Accepted by Nortbar
I can't open your VI, because I use an older version of LabVIEW.
I can say I can read your txt file without issues with "Read Delimited Spreadsheet.vi".
Question: Is your indicator long enough? The minus sign can act as a word wrap indicator.
(249 Views)
Accepted by Nortbar
Works for me. You need to pass a Space Constant as the delimiter.
I can't open your vi, like many people in this forum, because my latest version is LabVIEW 2021.
Paolo
(247 Views)
Accepted by Nortbar
It works just fine. My guess is you just have a display issue. Try expanding your string indicators to show more characters. The hyphen is often used as a marker for word wrapping.
(234 Views)
Accepted by Nortbar
UliB and pincpanter are on the mark!
All I did was make the indicators wider:
The data is all there!
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(230 Views)
Thank you guys !
Now I got it. Yes - just a display issue 😅
(215 Views)
