"Read delimited spreadsheed" stops at hyphen in string
Dear LabVIEW folks,
as I am still at the very beginning of learning, my question might seem a bit stupid.
I want to read a spreadsheet and write it to an array.
For this I use the "Read delimited spreadsheed" function.
It works fine, except if there is a hyphen (minus sign) in a string, then the cell is not read to the end.
How can I fix this without changing the original data?
Thank you in advance,
Nortbar
PS: I really tried long to understand the issue, but couldn´t find the answer.
(269 Views)
Accepted by topic author Nortbar
I can't open your VI, because I use an older version of LabVIEW.
I can say I can read your txt file without issues with "Read Delimited Spreadsheet.vi".
Question: Is your indicator long enough? The minus sign can act as a word wrap indicator.
(252 Views)
Works for me. You need to pass a Space Constant as the delimiter.
I can't open your vi, like many people in this forum, because my latest version is LabVIEW 2021.
Paolo
(250 Views)
It works just fine. My guess is you just have a display issue. Try expanding your string indicators to show more characters. The hyphen is often used as a marker for word wrapping.
(237 Views)
UliB and pincpanter are on the mark!
All I did was make the indicators wider:
The data is all there!
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(233 Views)
Thank you guys !
Now I got it. Yes - just a display issue 😅
(218 Views)
