Dear Darren,
Finally, I tried to use "Out Port.vi" under Windows 2000 (the AccessHW was added in NT as well as in 2000). It seemed to work (it means there was no more error "capability not supported", however it did not work (the result of reading a port using "In port.vi" was always 255, regardless the value I expected.
The configuration of board was exactly in the same state as before crash of Windows NT (no change of base address of board etc.). But it is true that both boards (custom one and PCI-MIO-E-16E-4) were removed and than reinstalled. The LabView program was without any change.
It is just my impression - I did not examine the problem very carefully, so may be there was some other reason of failing.
But finally we decided to reinstalled N
T, because of other (non-NI) devices which are not supported by Win 2000.
Thank you. Regards
Ferda
