10-30-2018 10:22 AM
Moving a large project, with an RT part, from LV2013 to LV2018.
Mostly went without a hitch, but do have a snag here.
On the RT side there is an "addon" which is a separate PPL, compiled separately from the main program, and can be "plugged in" without recompiling the main.
Works fine in LV 2013.
But it fails on LV2018.
Here is some code, with probes from LV2013.
Note that the result (probe 4) is a fully formed path to a file within an LVLIBP.
Here is the same code, with the same probes, from LV2018:
Note how probe 4 shows BLANK, which leads to a FILE NOT FOUND error, and failure. The file is definitely there, the INPUTS to "Get Exported File Path.vi" are the same, but the result is blank.
Any ideas?
Blog for (mostly LabVIEW) programmers: Tips And Tricks
10-30-2018 10:39 AM
Is LVOOP used in the Addon ?
If so...
chase down into all of the VIs that use LVOOP and look for a class constant that looks to be grayed-out. Put it in a diagram disable structure and drag a new instance into the diagram to replace the funky instance.
In a forum I can not link in public some have found that situation that drove me nuts the first time I encountered it. It was screwing up my error reporting functions used on a RT system and was preventing me from getting error reports on the Windows side of the application.
Otherwise ignore this post.
Ben
10-30-2018 12:46 PM
Is LVOOP used in the Addon?
No. It's used elsewhere on the RT side, but not in the addon itself.
10-30-2018 12:52 PM
Perhaps the rules have changed.
I am constructing the VI NAME to open by qualifying it with the library name and a colon.
i.e. probe 3 is "3C05A786 RTAC Addon for Barometer.lvlibp:RTAC Addon for Barometer.vi"
That was necessary in LV2013 - it says so in my comments, because it said so in the help somewhere.
If I DO NOT qualify it (i.e., simply ask for "RTAC Addon for Barometer.vi") in LV2018, it seems to work.
10-31-2018 08:46 AM
Hi Steve,
How would it affect your workflow if you used the "RTAC Addon for Barometer.vi" instead of qualifying it with the library name?
11-07-2018 07:55 AM
No problem, but it was my understanding that it was NECESSARY to qualify it in LV2013 - that's why I did it. I'd like to have one set of code that would compile and run both ways.
11-07-2018 08:05 AM
It was. Now LabVIEW fixed that.
