"ES" on serial read and write
Hello! I am using the Serial Read and Write example VI given by labview. When I connect it to my serial port, in the response section, it says "ES" after I run it. I want it to read numbers from a lab weighing balance connected through serial port. So what do I do?
Image attached below!
(805 Views)
What balance are you trying to talk to?  Could you link to the user and/or programming manual so we can see the communication protocol?
GCentral
(790 Views)
Hello! Thank you for your response. The balance I am using is a Mettler Toledo ML4002E balance. Attached is the manual! Thank you again!
(785 Views)
The *IDN? is not a valid command for this device.  To get a reading you need to send "S".
GCentral
(739 Views)
By sending S, do you mean that my command should just consist of S?
(736 Views)
Accepted by topic author sheetalp22
Hi sheetalp,
No, not "just" S…
Read your manual for your balance! I can recommend to take a closer look at chapter 23.2!
(730 Views)
That worked! Thank you!!
(716 Views)
