"ES" on serial read and write
Hello! I am using the Serial Read and Write example VI given by labview. When I connect it to my serial port, in the response section, it says "ES" after I run it. I want it to read numbers from a lab weighing balance connected through serial port. So what do I do?
Image attached below!
(809 Views)
What balance are you trying to talk to?  Could you link to the user and/or programming manual so we can see the communication protocol?
GCentral
(794 Views)
Hello! Thank you for your response. The balance I am using is a Mettler Toledo ML4002E balance. Attached is the manual! Thank you again!
(789 Views)
The *IDN? is not a valid command for this device.  To get a reading you need to send "S".
GCentral
(743 Views)
By sending S, do you mean that my command should just consist of S?
(740 Views)
Accepted by sheetalp22
Hi sheetalp,
No, not "just" S…
Read your manual for your balance! I can recommend to take a closer look at chapter 23.2!
(734 Views)
That worked! Thank you!!
(720 Views)
